Mały sterownik blokowy z LCD zakupiony na aliexpress:
https://www.aliexpress.com/item/3296386 ... 4c4d84BTRS
Mały 15A 350W 38V z LCD 160 zł.
Niby nic nadzwczajnego ale ciekaw propozycja do lekkiej konstrukcji, składaka. Kiedyś nie bylo możliwości mieć roweru samoróbki z LCD programowalnego jak fabryczny. Teraz za niewielkie pieniądze można ( 163 zl ). LCD model S830 wraz z przyciskiem na kierownicę.
Będzie założony w whelelrze 250W wraz z większą baterią.
OPIS:
Features
- OVER-HEAT PROTECTION: Power will turn off when over-heat, and restart if the temperature is normal.
- OVER-LOAD PROTECTION: When overload happens,the motor stall more than 2 seconds, the controller will cut off the current out-put to protect the motor and battery.
- DUAL MODE: If the hall motor sensors are broken, controller will operate to None-Hall mode.
- EABS Function:better brake,extend the riding mileage without damaging the motor.
- LOW-VOLTAGE PROTECTION FUNCTION helps to extend the battery life.
- BRUSHLESS CONTROLLE: working silently and sensitive.
Self-learning matching steps
- Connect Motor Phase Line and Hall Motor Phase line
- Connect the battery
- Link Two green learning lines together
- Connect the LCD/Smart Display and turn it to the highest level
THE MOTOR WILL ROTATE AFTER SELF-STUDY.
- If it rotates reversely, disconnect the learning line directly, and then plug it in, it will then rotate forward.
- Keep rotating forward for about 20 seconds, then directly disconnect the learning line.(DO NOT TURN OFF THE SWITCH)
- If it learns successfully which means the learning line will not be needed anymore,you can test the motor by plugging in the throttle.
Display
Material: ABS +High Hardness Acrylic
Voltage:DC 24V/36V/48V
Cord Length:180cm
LCD Display Size:90x53x14MM
Smart Display Size:85x52x33MM
Note
- Keep pressing 3 seconds for turning on/off
- SPCP between Display and Controller, could not match other controllers
Notes
- Turn off the power before wiring, and connect each wire as shown in the wiring diagram.
- The controller should be installed in a place where is ventilated, waterproof, and shockproof.
- The controller connector should be plugged in, and it is forbidden to reverse the positive and negative terminals of the controller power supply.
- LCD/Smart display comes with mount ,suitable for 22mm handlebar.
- Suitable for LITHIUM BATTERY type electric bicycles
Package Includes
1 x Motor Controller
1 x LCD Display or Smart Display
Similarities
differences
color
LCD Display
Speed Display
Gear Shifting
Power Indication
Fault Indication
Total Mileage
Single Mileage
Cruise
Sterownik blokowy 15A 350W 48V LCD ( S6-51 ) + LCD S830
- elektrotonus
DISPLAY S866 podobny zestaw
Z bardzo rozbudowanym wątkiem do tego displaya i kontrolera https://www.pedelecs.co.uk/forum/thread ... ler.32911/
Re: Sterownik blokowy 15A 350W 48V LCD ( S6-51 ) + LCD S830
Potrzebuje ustawien parametrow hd-b3 ,17.5Ah,48v, 1200w.
DISPLAY LCD BMS-S830 24V / 36V / 48V.
