E bike 5200W
Okazje, promocje, linki, sklepy, opinie
Ropuch
E bike 5200W
Post autor: Ropuch »
Czesc, znalazlem w sieci oferte e bika na sprzedaz, ja zielony jestem w temacie, dopiero zaczynam. Moglibysci przeczytac specyfikacje tego e bika i sie wypowiedziec? silnik ma 3000W tu w opisie ale sprzedajacy napisal mi ze ma 5200W czyli co? stuningowal go? Pozdrawiam i dziekuje.
E-Bike Specification
1. Frame: FC-1 FRAME
Material: Steel/2mm
Color: Black Frame
2. Front Fork: DNM USD-8 Bike Fork
3. Rear Suspension: DNM BURNER-RCP3 Air Suspension
4. RISUNMOTOR 34.9mm Aluminium Alloy Seattube Clipper
5. SELLE ROYAL 5130HR Ergonomic Seat with SR BLINKING LIGHT
6. RISUNMOTOR 78*140 Bearing Bottom Bracket
7. PROWHEEL Aluminium Alloy Chainwheel + Cranksets
8.RISUNMOTOR CNC Aluminum Alloy high density bearing pedal, super long life
9.RISUNMOTOR Aluminum Alloy Stand
10. Front wheel:
24x3.0"t; Front wheel (with 24x3.0" Off-Road Tire or City Tire)
RISUNMOTOR Strong Double-wall Aluminium Alloy Rim
12g Spokes, NOVATEC DH hub (support disc brake)
11.Braking System:
TEKTRO AURIGA E-TUNE (HD-E530) Hydraulic Disc Brake, cut off power
TEKTRO 203mm Front & Rear Disc Brake Rotors
12. Groupset:
DNP Single Speed Freewheel
13. HONSUN Handlebar, Stem and Seatpost:
Aluminum Alloy Riser Handlebar (Width: 760mm)
80mm Aluminium Alloy Stem
30.9mm Aluminium Alloy Seatpost
14. 72V 3000W 24x3.0" Rear Wheel:
RISUNMOTOR Strong Double-wall Aluminium Alloy Rims
High Quality 18 MOSFET 50A ±1 Sine Wave Controller (Support Regenerative Function, will charge battery during braking)
48V- 72V Universal Voltage Full color TFT RSM-750c Display (with 5-level PAS, speed limit, speed display, Cruise, Regenerative Function)
Throttle Drive / PAS Drive (Torque sensor simulated)
Remote start + Alarm + Motor Lock
Full Speed: about 80-90km/hour
15. Battery:
72V 35Ah Li-ion (Max Capacity, Samsung 3500mAh Cells)
Mileage: About 65-75km with pure battery per full charge; about 85-95km with PAS
Dzjohnyj
Re: E bike 5200W
Post autor: Dzjohnyj »
Moc podawana przez sprzedawcę odnosi się do dwóch cech: to ile jest wartością nominalną silnika oraz drugie - ile sterownik może maksymalnie dostarczyć. Jednocześnie te dwie wartości nie kłucą się z sobą, bo silnik może przyjąć prądy o wiele wyższe od przewidzianych (aczkolwiek pod dłuższym wpływem może się zwyczajnie spalić).
Co do samej konstrukcji - raczej nie warto. Zobacz sobie produkty takie jak: Kariwa oraz Falcon.
grafffik
Re: E bike 5200W
Post autor: grafffik »
przy ew. zakupie spoza Europy pamiętaj by do ceny doliczyć cło antydumpingowe 48% od wartości, 23% vat i opłaty celne
Ropuch
Re: E bike 5200W
Nå ile zlociszy wycenilibyscie tankiego e bika? Mozecie polecic sprawdzone pres was sklepy, pudding ktorzy mogliby zlozyc min e bika podobnego do tego z ogloszenia tylko troszke lepszego, zebym mogl pojezdzic po gorkach? Ja mieszkam poza granicami EU (Norwegia) i jest maly problem bo sprzedawca (sklep)powinien med numer EORI , tak bynajmniej uslyszalem od przewoznika .
Pozdrawiam.
leszcz
Re: E bike 5200W
Post autor: leszcz »
Próbuj z Vasylem
https://www.olx.pl/oferta/adrenalin-72v ... sZ92x.html
https://allegro.pl/oferta/adrenalin-72- ... 8014618334
Ewentualnie zapłać komuś, żeby ci przywiózł w bagażniku jako swój.
