Bafang GVT
Bafang GVT
Post autor: Yin »
Ciekawostka od bafanga, silnik hub z przekładnią planetarną 5 biegową:
Bafang GVT:
The 5-Speed Automatic Gear hub – The Latest GVT Technology Masterpiece
As the latest innovation on the GVT platform, the G500A is a 5-speed automatic gear hub
specifically crafted for high-powered fat-tire eBikes, designed to effectively tackle challenging
terrains like snow and sand. G500A can withstand torque ratings of up to 200N.m, thus
significantly reduces the impact and damage to the chain and freewheel caused by high torque.
While G500A could supports high speeds of 45km/h and 60km/h. It is available with 175mm and
190mm dropout options. Bafang’s commitment to quality and reliability is reflected in its rigorous
testing standards. Each of the five gears in the G500A undergoes at least 10,000 impact tests,
ensuring durability and rider confidence.
https://www.bafang-e.com/uploaded/news/ ... 276816.pdf
Tu go można zobaczyć:
Re: Bafang GVT
no tak ale na alibabie pytales ? bo o tym juz czytalem jakis czas temu i cisza
Re: Bafang GVT
Re: Bafang GVT
aaa to nie dopatrzylem , yinowi sie ehh#liło - to nie jest silnik tylko piasta do mida
